Download the full macOS installer, open the free Bootabler app, select the installer, choose a disk image format (ISO, CDR, DMG, VMDK, VDI, VHD, VHDX, QCOW2 or raw IMG) instead of a USB drive and click Create. Manually, build a disk image with hdiutil, run createinstallmedia onto it and convert it to an ISO.
A bootable macOS ISO, DMG, VMDK or VHD image is a copy of a macOS installer packed into one file, so you can keep it as an archive, boot it in VMware, VirtualBox, Parallels or UTM, or load it in an emulator instead of plugging in a USB drive. This guide explains what each format is for and shows two ways to make one: the easy way with the free Bootabler app, and the manual way with Terminal.
Steps at a glance
- Download the full macOS installer you want. It appears in your Applications folder as Install macOS ….
- Open Bootabler and select that installer.
- Choose a disk image format instead of a USB drive (ISO, CDR, DMG, VMDK, VDI, VHD, VHDX, QCOW2 or raw IMG), then click Create and enter your administrator password.
- Attach the finished image to your virtual machine or emulator, or keep it as a bootable installer archive.
Which format do you need?
Bootabler can save the installer in these formats. Pick the one your virtualization or emulator app uses.
| Format | Works with |
| USB installer | Real Macs: clean installs, recovery, OpenCore and Hackintosh installs |
| ISO (.iso) | Boot it in VMware, VirtualBox, Parallels or UTM, or burn it to disc |
| CD/DVD master (.cdr) | Apple's disc master format, also the step before an ISO |
| Compressed disk image (.dmg) | Parallels and Finder |
| VMDK | VMware Fusion, Workstation and ESXi, and VirtualBox |
| VDI | VirtualBox |
| VHD | Hyper-V, Virtual PC, VirtualBox and Parallels |
| VHDX | Hyper-V (needs qemu-img) |
| QCOW2 | QEMU and UTM (needs qemu-img) |
| Raw disk (.img) | QEMU, UTM and dd |
qemu-img is a free command-line tool that comes with QEMU. Bootabler uses it for the VHDX and QCOW2 formats, so install QEMU first if you pick one of those.
If you only need to install macOS on a real Mac, a USB drive is simpler; see How to create a bootable macOS USB installer.
What you need
- The full macOS installer app for the version you want, for example Install macOS Sequoia.app, in your Applications folder. You can get it from the App Store, from Software Update, or as an InstallAssistant.pkg package.
- Free disk space for the image, about the size of the installer plus a few gigabytes. Recent installers are around 15 GB.
- An administrator account on the Mac you use to build the image.
Method 1: Create the image with Bootabler (no Terminal)
- Download Bootabler and open it. It scans your Applications folder and lists every macOS installer it finds. You can also add an installer from another folder or an InstallAssistant.pkg file.
- Select the macOS version you want in the sidebar.
- Choose to create an image instead of a USB drive, and pick the format from the list (ISO is the default).
- Click Create and enter your administrator password when prompted. Bootabler runs Apple's own
createinstallmediatool and shows each step in its built-in Terminal view. - Wait for the completion notification. The image is saved where you chose.
Bootabler works with System Integrity Protection enabled and can build installers for any macOS from OS X Mavericks 10.9 to the latest release.
Method 2: Create a bootable macOS ISO with Terminal
This is the widely used manual recipe. It builds a blank disk image, runs createinstallmedia onto it, and converts the result to an ISO. Replace Sequoia with the name of your installer, and make the image larger than the installer.
# 1. Create a blank, mountable disk image
hdiutil create -o /tmp/macOS -size 20g -volname macOS -layout SPUD -fs HFS+J
# 2. Mount it
hdiutil attach /tmp/macOS.dmg -noverify -mountpoint /Volumes/install_build
# 3. Write the installer onto it
sudo "/Applications/Install macOS Sequoia.app/Contents/Resources/createinstallmedia" --volume /Volumes/install_build --nointeraction
# 4. Unmount (the volume is renamed after the installer)
hdiutil detach "/Volumes/Install macOS Sequoia"
# 5. Convert to an ISO on your Desktop
hdiutil convert /tmp/macOS.dmg -format UDTO -o ~/Desktop/macOS.cdr
mv ~/Desktop/macOS.cdr ~/Desktop/macOS.iso
If you only need a DMG, stop after step 4: /tmp/macOS.dmg is already the bootable image. For VMDK, VDI, VHD, VHDX or QCOW2, use Bootabler, or convert the raw image yourself with qemu-img convert.
Using the image in a virtual machine or emulator
- Create a new virtual machine in your virtualization or emulator app and give it a virtual disk to install onto.
- Attach the ISO as the optical drive, or attach the VMDK, VDI, VHD, QCOW2 or raw image as a disk, according to what your app accepts.
- Start the machine so that it boots from the image, then follow the macOS installer.
On Apple Silicon Macs, apps built on Apple's Virtualization framework install macOS guests from an IPSW restore image rather than an ISO. ISO and virtual disk images are mainly for Intel virtual machines, emulators, and OpenCore or Hackintosh setups. Check which image types your app accepts before you build one.
Which macOS versions can you use?
Bootabler can build installers for macOS from OS X Mavericks to the latest release, including Tahoe, Sequoia, Sonoma, Ventura, Monterey, Big Sur, Catalina, Mojave and High Sierra. The Mac that builds the image must run macOS Big Sur 11 or later.
Troubleshooting
- The image is too small:
createinstallmediafails if the image is smaller than the installer. Use a larger-sizevalue. - "This copy of the Install macOS application is damaged": download the installer again. The installer also needs to be the full app, not the small stub that Software Update downloads.
- VHDX or QCOW2 fails: these two formats need qemu-img. Install QEMU, then try again.
- The virtual machine does not boot the image: check that the machine is set to boot from the optical drive or disk where you attached it, and that your app supports the image format.
- Apple Silicon host: an ISO of a macOS installer will not install as a guest in apps that use the Virtualization framework. Use an IPSW there.
Related guides
- How to create a bootable macOS USB installer
- How to create a multi-boot macOS USB installer
- ISO Image Creator: convert DMGs and folders into ISO images
- Bootabler: free bootable macOS USB and disk image creator
