Open Terminal and run sudo spctl --master-disable, then choose Anywhere in System Settings › Privacy & Security. Turn it back on with sudo spctl --master-enable. Gatekeeper Toggler does the same with one switch.
Gatekeeper is the macOS security check that decides whether an app downloaded outside the Mac App Store may run. If an app is unsigned, not notarized or from an unidentified developer, Gatekeeper blocks it. That is usually the right call, but sometimes you need to run a build you trust, such as a test version or a tool Apple has not notarized.
Try the safer option first. If only one app is blocked, open that single app with Open Anyway in System Settings › Privacy & Security (on macOS Sonoma and earlier, Control-click it and choose Open). Gatekeeper stays on for everything else.
Turn Gatekeeper off with Terminal
- Open Terminal.
- Run
sudo spctl --master-disableand enter your administrator password. - Open System Settings › Privacy & Security, scroll to Security, and choose Anywhere if it is offered.
- Open or install the app that was blocked.
- Turn it back on with
spctl --status
spctl --status tells you whether Gatekeeper's assessments are currently enabled or disabled.
Turn it off with one switch
Gatekeeper Toggler flips Gatekeeper on or off from a single switch. A green padlock shows when it is on, each change asks for your administrator password, and it simply runs Apple's own spctl commands for you. It is free and runs on macOS 11 Big Sur or later.
Be careful
With Gatekeeper off, any app can run, including a malicious one. Turn protection back on as soon as you are done. For background on another macOS protection that often comes up alongside this one, see What is SIP?
