Sign your app updates.
Sparkler creates signed Sparkle appcasts and disk images for apps you host yourself, with no notarization and no Apple Developer account.
Generate an appcastVerify UploadGet Sparkler1. Drop your file
Drop a .app, .exe, ZIP or folder onto Sparkler.
2. Check the details
Confirm the version, title and Update File URL.
3. Generate and upload
Click Generate Appcast, then upload the file Sparkler names.
4. You stay in control
Everything stays on your Mac until you upload it. Use Verify Upload to confirm.
Generate an appcast
Turn an update file into a signed Sparkle appcast.
Drop or select
Drop a .app, .exe, ZIP file or folder onto the window, or click Select File. Sparkler reads the version and app name for you.
Update File URL
Pick the saved URL where the update will be hosted. This field is required.
Release Notes
Edit the HTML release notes, or import a changelog file.
Generate Appcast
Signs the file with your EdDSA key and writes appcast.xml (or appcast-windows.xml for an .exe) next to the source file.
- Drop your app or installer onto the window.
- Check the version, title and Update File URL.
- Click Generate Appcast.
- Upload the file named in the result message, plus the appcast, to your server.
Windows installers
Sign a Windows .exe on your Mac.
Signed as is
A dropped .exe is not zipped. The .exe itself is signed, and the appcast length and signature describe that exact file.
Windows appcast
The appcast is saved as appcast-windows.xml and includes sparkle:os="windows".
Version from filename
A name like MyApp-1.2.3.exe or MyApp_1.2.3_Setup.exe gives version 1.2.3.
Same key
Windows and macOS updates use the same EdDSA key. The Windows app must contain the matching public key.
Verify Upload
Check that your server serves the file you signed.
What it does
Downloads the file at your Update File URL without any cache and compares its size and SHA-256 with the signed local file.
If it matches
The server copy is byte-identical, so the appcast signature and size are valid.
If it differs
Sparkler reports the HTTP status and explains likely causes: an error page, a stale CDN copy, a truncated upload, or an FTP upload in text mode.
- Generate the appcast and upload the file.
- Click Verify Upload.
- Read the result in the sidebar.
Applications URL
Save the download URLs for each app once.
Add New URL
Enter an App Name, an Update File URL and an optional Release Notes URL.
Auto-detect
When you drop an app, Sparkler matches it to a saved URL by its real name.
Edit or remove
Change or delete a saved URL from the list on the Applications URL tab.
Create a DMG
Build a disk image from a dropped .app.
Engine
Use the built-in engine (nothing to install) or the external create-dmg tool.
Window and icons
Set the window size, icon size and background image.
Background text
Add text with position dropdowns, font size and font weight.
Volume icon
Pick a custom icon or one of three bundled icons, or turn on Use Generic Volume Icon for the standard macOS disk icon.
Signing and ZIP
Optionally sign the DMG, create a .dmg.zip and add the version to the filename.
Keys and tools
Manage the signing setup.
EdDSA keys
Sparkler uses the key stored in your Keychain, or creates one if none exists.
Sparkle tools
Use the bundled tools or choose your own folder in Settings > Sparkle.
Validate Setup
Checks your public key and the Sparkle framework inside a dropped app.
Settings
Open Settings with the gear icon in the toolbar.
| Section | What it controls |
| General | Auto-extract app info, detailed error messages, preserve file locations, bundle appcast and archive. |
| Updates | Sparkler’s own automatic update checks. |
| Sparkle | Sparkle tools location and EdDSA keys. |
| About | Version, credits and donation. |
Shortcuts
Keyboard shortcuts.
| Keys | Action |
| ⌘O | Select ZIP file |
| ⌘W | Close window |
| ⌘⌃S | Toggle sidebar |
Why does my update say it is improperly signed?
The file on the server is not the file that was signed, or the public key in your app does not match your EdDSA key. Use Verify Upload to compare the server copy with the signed file.
What is the Release ZIP?
With Bundle Appcast and Archive on, Sparkler also makes a ZIP holding the appcast and the update file for convenience. Do not upload it as the update itself.
Why do I get a 525 error from my server?
525 is a Cloudflare error: it could not complete an SSL handshake with your origin server. Check the origin SSL certificate and Cloudflare’s SSL mode.
A new upload still serves the old file.
A CDN may be caching the old copy. Purge the cache or use a new filename for each release.
Does Sparkler need an Apple ID or notarization?
No.
